8070 Powershift
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Powershift
    Posted: 12 Oct 2010 at 9:47pm
Having a hard time shifting from low to high on an 8070. Is it an adjustment or may it need a new cable? One of them was replaced recently. It's kind of slow on the road in low range!
HD16,917H,185,7050,8030FWA,8050FWA
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 9:50pm
Take the panel up in the floor and see if the shift cable is moving the transmission shift lever freely.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 1:20am
On my 8050, it was kind of tough getting it out of low range, also. Learned a few tricks to it. I don't know if you realize it, but putting the clutch tight to the floor applies a transmission brake, so if you put the clutch all of the way to the floor for a second, then release it part way and shift it out of low quickly, it will usually go easily. Also, if you are rolling slowly, put your foot on the clutch, but not all the way, then shift it out of low, it'll usually come out easily.  Hope this helps.  Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 6:13am
An old/stiff cable on the range shift lever can make the effort very high and hard to shift. Replace the large cable and I'm sure you'll see and improvement.
Jim in SE ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in SE ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 7:31pm
My 8030 is that way like it drags alittle, not the handiest but if I shift to reverse then the range shift works good. takes pressure off I guess.
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2010 at 8:22pm
 Yes , the reverse trick helps also on our 8070 when shifting back into park.
This page was generated in 0.089 seconds.
