8070 Oil Leak |
Eugene
Joined: 11 Sep 2009 Location: Ayr, Australia Points: 18 |
Topic: 8070 Oil LeakPosted: 21 Mar 2010 at 4:14am |
I have an 8070 FWA with an oil leak between the engine block and the rear of the timing case. I have found that a couple of the bolts around the water pump have snapped off and fallen out. The gasket between the block and rear timing case cover is working its way out. I have been through the workshop manual and it looks like I can get the rear timing cover off without pulling the camshaft. All I have to do is remove the cam gear. Is this possible ? Is there anything to watch out for ? Can the gear be refitted to the camshaft easy enough ? |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8755 |
Posted: 22 Mar 2010 at 11:28pm |
You have it right.The cam gear has a bolt holding it on with 1/2 of a 1/2 moon key.May not even need a puller to remove gear(can't remember) but it doesn't come off hard.Shouldn't be hard to reinstall. (Mines still apart)
Edited by SteveM C/IL - 22 Mar 2010 at 11:30pm |
