8070 motor fail |
Page <123> |
bhuffaker1
Posted: 04 Jun 2021 at 11:20pm |
bhuffaker1
Posted: 04 Jun 2021 at 11:26pm |
Not sure the head is even rebuildable?
Thoughts on pictures? Not sure using this head is even an option. |
bhuffaker1
Posted: 04 Jun 2021 at 11:27pm |
price includes the adapter plates....
KJCHRIS
Posted: 04 Jun 2021 at 11:29pm |
Pictures look like it didn't burn a piston but dropped a valve, which beat hell out of piston and head, you'll also want to have that rod checked for damage.
I'd do an out of frame complete rebuild or replace on that engine.
bhuffaker1
Posted: 04 Jun 2021 at 11:30pm |
Rod was bent to hell..... Head looks too damaged to reuse?
bhuffaker1
Posted: 04 Jun 2021 at 11:31pm |
I had a friend take the head off and he told me piston was melted but I agree with you KJCHRIS . Dropped a valve for sure.
bhuffaker1
Posted: 04 Jun 2021 at 11:32pm |
Anyone have a rebuilt Motor for this tractor here on this form??
shameless dude
Posted: 05 Jun 2021 at 2:52am |
you live near greeley?
Posted: 05 Jun 2021 at 6:52am |
All exhaust valves from an engine that has had the timing advance fail need to be scrapped.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8162 |
Posted: 05 Jun 2021 at 7:10am |
I don’t want to sound out of line here, but, what does this tractor run/pull when it’s working? Is it possible that you are expecting too much from this tractor? You may have too much of a load on it? Just curious what you use this tractor for?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5123 |
Posted: 05 Jun 2021 at 10:30am |
Looking at the first head pic, the injector seems to be the cause of your issue, can see where it was spraying back on the head and valve, and continued use with it running poorly, will make it $h!t the bed. Not in any way the engine's fault. Fix what you have and get it back in the field. Too bad I'm no longer living in Colo lol! That head will need replaced, plenty of good used heads around to be acquired. Leaving an old copper washer in there, and adding a new one with the injector can cause it to not spray in the piston bowl, but on the head surface. Overhaul it, and get another head core to have rebuilt.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681 |
Posted: 05 Jun 2021 at 11:06am |
6 sleeve kits,different head w/all new valves(set at correct surface height),attention to detail when assembling and probably ok to use that Ambac. I'm like others and think life was better with Roosa's but M 100's are ok when they are right. I would put a pyrometer on it just to monitor exhaust temps. If pump retards,exhaust will show it. That for sure dropped a valve and bent your rod but most likely from what Doc said about reusing over heated parts from earlier failure. Can anyone speak to any harm to crank from bending a rod like that?
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3580 |
Posted: 05 Jun 2021 at 2:25pm |
Bhuffaker1, welcome. Hear what you’re saying about being tired of spending money & then it’s not reliable. You’ve also stated in your previous posts that your 8070 has already received a new radiator, new turbo, 8500hr, & otherwise decent shape. From pictures I see it is a Fwd - right? Is it PS or PD transmission?
Lots of great advise on this AC forum. So with that support/direction, rebuilding its current AC 670I engine might be best money spent going forward? Then you should know exact condition of the engine. 7050’s engine might do ok too? It’d compliment your 7080’s likeness. Always a chance for 7050 engine to have issues later though. Cummins 5.9 would be a good engine, but it’s conversion will be expensive. You say you have little to no local AC support. So if you can locate a good local Cummins support, that may be another good direction for you & any future issues? Good luck whatever you decide! Edited by AC7060IL - 06 Jun 2021 at 2:58pm |
bhuffaker1
Posted: 05 Jun 2021 at 10:32pm |
I am about 5 hours north.. Opposite end of the sate...... Easily a days drive though.... What are your thoughts? |
bhuffaker1
Posted: 05 Jun 2021 at 10:33pm |
This tractor would get hot just driving down the road on a hot afternoon day.. The only thing that I used it for was hooked up to a JD 568 round baler and I loved the transmission for that... |
bhuffaker1
Posted: 05 Jun 2021 at 10:39pm |
Power shift.. Yes I am tired of spending the money on the tractor but it just proves that I have NO relieable AC mechanics around here. I have done tons of work and then had it looked about by two different shops.. I just have had EXCEPTIONAL luck with the old 7080.. It is a rock.... Struggling for sure to make a decision........ THANK YOU!
bhuffaker1
Posted: 05 Jun 2021 at 10:45pm |
I know I do not have the know how to do what you are saying. If I had a good AC mechanic here I would rebuild but there really is no one who knows theses engines even remotely close to me. I am really considering going with the 8.3 and spending the 10k and getting a machine that should last a long time.... I would send this motor to someone but that also starts to break the bank in just shipping costs. I made a mistake when I bought this tractor years ago. I should have bought a tractor that either I could support of have mechanics that can support it. THis is Green country around here. Case as well.... I would just like to get something in this machine that I can trust to run and do well. It is a money pit because there is no one here who can fix it right the first time. Thanks for the post!
bhuffaker1
Posted: 05 Jun 2021 at 11:07pm |
Here is my email in case someone here may know "a guy" who can either rebuild this correctly or sell me a rebuilt motor. If not, I may have no choice but to go with either the 5.9 or the 8.3
Please have them reach out to me...
bhuff.ncsd@gmail.com |
Mikez
Posted: 05 Jun 2021 at 11:25pm |
I don’t know anything on this topic. Unless these motors that your thinking of buying came out of an 8070, you might end up half to three quarters of an engine swap to find hard to find puzzle pieces and regret the decision.
Jwmac7060
Posted: 05 Jun 2021 at 11:40pm |
Dont waste anymore money. Swap it out for an 8.3 Cummins. We put one in an 8070 and it was a completely different tractor.Allis never should have put those junk pumps on anything
BKarpel
Joined: 27 Apr 2012 Location: Collinsville IL Points: 113 |
Posted: 06 Jun 2021 at 1:35pm |
You should rebuild your motor. At least you know what you have. The other 426 may last a long time or quit tomorrow. When doing a overhaul have the pump and injectors tested. Could replace pumps and even put a A pump on. A cummins swap will require a motor adapter plate and flywheel modification. I think the frame rail gets cut to make room. How can injectors be put in wrong when they have lines to match up to?
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4556 |
Posted: 06 Jun 2021 at 2:09pm |
About a month ago, I looked at a brown belly 7580 that was supposed to have a rebuilt engine. There were other issues so he was willing to sell at a part out price. I didn't pull the trigger, but if it has not sold and I bought it , the engine would be available. Also has 32" wheels. I'm a long way from you in Ontario.
bhuffaker1
Posted: 06 Jun 2021 at 3:08pm |
I have no idea how much shipping would be? Prob a small fortune where it would have to come across the boarder.. I wish you were closer.....
bigal121892
Posted: 06 Jun 2021 at 3:35pm |
The injectors can be installed in one of two positions, one correct the other incorrect. If all the injectors have been removed, and the first one is installed wrong, and the rest are installed like the first one, the return line will match up, and you will never know the difference, unless you are familiar with how the injectors are to be installed. It's been a long time, but if remember correctly, the line needs to go between the injectors and the valve cover.
injpumpEd
Posted: 06 Jun 2021 at 6:55pm |
Correct, return line towards valve cover on engines with American Bosch injectors. Sometimes guys put them the other way thinking the returns are easier to get to, not realizing the holes in the tip are at an angle to compensate for the injector sitting in the head at an angle. Allis Chalmers built injectors are foolproof, inlet on side, return on top.
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 256 |
Posted: 06 Jun 2021 at 7:19pm |
How can I tell which injection nozzles are on my 8010 that has a M-100 pump on it? Thanks Dave
SteveM C/IL
Posted: 06 Jun 2021 at 9:57pm |
If it's got an Ambac pump...it has Ambac injectors...fuel line on top,return on side.
Edited by SteveM C/IL - 06 Jun 2021 at 9:58pm |
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
Posted: 07 Jun 2021 at 9:07am |
Even the early 8010 with the Roosa pump still had Ambac injectors from the factory.
bhuffaker1
Posted: 07 Jun 2021 at 9:23am |
It is a very touchy injection system. This is why Shops around here do not like to work on these engines and hence my dilemma. The Rosa master pump and injectors in my opinion was by far a superb system. I know understand that AC wanted to not make as much black smoke and start a little easier but those fuel systems just seemed to work and work well. Not near as touchy. Who makes an injector that can be put in backwards and still somewhat work? I have learned so much from each of you and thank you for your time and input. I hope to make a decision in the next few days....
injpumpEd
Posted: 07 Jun 2021 at 10:37am |
Many engines have injectors that can be installed "backwards" so to speak. The Roosa pumps on about 150hp tractors and up were kinda past their comfort zone. The M100 is a good pump, kinda complicated by design, but IH tractors been running them since 71. They did allow AC engines to smoke a little less. For some reason though, the AC engine is much more sensitive to governor surging with the M100's and even more so with the Bosch A pump inline. The one or two A pump conversions I've been involved in had surging issues, which is why I cannot do those at this time. I'm no engineer, and sure don't have time to listen to callers complaining about a surge issues. The biggest issue giving the AC M100's a black eye is poor quality rebuilds.
Page <123> |
