8050 Hydraulic Couplers
coltonconverse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coltonconverse Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Hydraulic Couplers
    Posted: 03 Nov 2024 at 12:28pm
I just recently bought an 8050, and when trying to hook up our 13 shank IH 5500 chisel, I realized the Pioneer fittings on the chisel do not fit the 8050 couplers. What type of couplers does the 8050 have? Is there an adapter I could use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 12:54pm
HMMMMM ! I have 2 8070's and they both have pioneer female fittings. The 83 has the first design release while the 85 has the lock lever allowing pressurized hook/unhook. What number on you chisel fitting?....and are you sure they don't fit? Sometimes the 83 is is a t**d to connect.
Edited by SteveM C/IL - 03 Nov 2024 at 12:56pm
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 4:16pm
The 8050 should have ISO couplers. Standard Pioneer couplers should mate up, but might be a bit loose.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 4:50pm
Are you saying there is a diameter difference between your IH chisel & 8050? Like 1/2” coupler on 8050 verses maybe either a 3/8” or a 3/4” on chisel??
Edited by AC7060IL - 03 Nov 2024 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 5:07pm
Best way to connect hoses is with both remote levers in FLOAT and engine off.
