8050 Compensator Reseal
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Compensator Reseal
    Posted: 23 Apr 2024 at 2:53pm
Working on my 2wd 8050. The hose running from the remote stack down to the top of the compensator valve rubbed through and I got it replaced last night. I had to loosen the ORB adapter on top of the valve so I could turn the hose and get a wrench on it. Now it looks like the o-ring on the fitting is leaking, but there isn't enough room to unthread the adapter from the top of the compensator. Do I need to drain the oil out of the hydraulic system before I remove the compensator valve? Don't want to pull the 4 bolts out and be surprised when im covered in hydraulic fluid.
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2024 at 6:29pm
If you have the parts on hand, you won't lose that much oil. The oil will leak out of the pump front plate, while the compensator is off, but it doesn't just gush out. Have a clean pan or bucket available to catch it and reuse it, if you want.
