8030 Trans Filter Light |
dnel45
Joined: 13 Oct 2009 Location: Northwest Ohio Points: 164 |
Topic: 8030 Trans Filter LightPosted: 18 Jun 2024 at 8:33am |
Had ‘Trans Oil Filter’ light come on our 8030 PS today. Filter was changed approximately 90 hours ago. Complete fluid change approximately 200 hours ago. 3400 hours on tractor. Oil level fine. What would cause this? Should filter be changed again? Bad sensor? Also - no change in performance, shifts flawlessly.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 649 |
Posted: 18 Jun 2024 at 1:55pm |
Id start with the sensor. Had a engine oil pressure switch go bad on a 8070. Light came on in the field. Shut it down immediately. Put a guage on it and it had great oil pressure. They do fail all of a sudden
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
JPG AUSTRALIA
Posted: 18 Jun 2024 at 6:55pm |
Check for the sender wire rubbed through and grounding
8070nc
Posted: 18 Jun 2024 at 8:47pm |
Thats a good suggestion. Wire grounding is a real possibility
1984 80780
SilverShoes
Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 171 |
Posted: 20 Jun 2024 at 9:56am |
I’d check your wiring, common issue with the light coming on.
