8030 TB Lever ?
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 8030 TB Lever ?
    Posted: 02 May 2011 at 10:18am
If you will notice in the picture I have an issue with the cover for the traction Booster lever.  The slot with decal for the lever is at the bottom of the cover and someone just cut a notch out of the top for where the lever actually sits.  I took the cover off and I do not see how the lever brackets would allow it to orient that low.  Do I have a cover from a different tractor is my linkage screwed up?  Mike
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:57pm
My 8030 doesn't have that lever, is it an early one or a late one?
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:58am
The late 8000 series had that set up . Is your lever a s shaped if it is I think they have your linkage messed up Niel
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:11am
Your lever is mounted incorrectly, or the wrong lever has been mounted.  It should fit the shield down below, where the slot and decal are.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 11:58am
Let me see about getting a picture tonight with the shield off. Thanks for the help so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:30pm
Here are some pictures of the OEM lever and parts from my 8010:
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 11:41pm
My 8050 is the same as his 8010
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:44pm
ditto for my 8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:05am
Thanks a bunch Russ.  Looks like somebody put a different lever on, I wonder what is originally off of? Your interior certainly looks a lot better than mine, i guess it is getting time for a new cab kit.  Mike
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:17am
That used to be the right lever. You can see were it broke off at the bottom, then somebody fixed it by cutting off the offset, and welding it on up top, that is not a factory weld you see there.  also looks like the bend at the knob has been striaghtened may even be vice marks there too.  Probably better design, but the cover dosen't work with it that way.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:02am
I think that is a very likely senario Orange Blood.  Anybody have a good used lever and cover available?  Mike
Edited by Michael (WI) - 09 May 2011 at 10:02am
