8010 exhaust manifold |
eskinner
Joined: 24 May 2023 Location: Hay Springs Points: 2 |
Topic: 8010 exhaust manifoldPosted: 24 May 2023 at 11:40am |
We thought we would probably be able to find someone on here to answer our questions better than anyone else. On the exhaust manifold we were trying to find what the tightening sequence is and also how many ft lbs. of torque to tighten too? Thanks!
Posted: 24 May 2023 at 12:00pm |
The bolts are a special bolt from AGCO only. Do NOT use the lockwashers they use. Get a hardened Grade 8 flatwasher. 45 ft lbs with lubed threads.
Edited by DrAllis - 24 May 2023 at 5:02pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4120 |
Posted: 25 May 2023 at 8:17am |
Doc, does that apply to all 301's or just the 8010?
Posted: 25 May 2023 at 8:26am |
ALL 301's have a special exhaust manifold bolt that has "self-locking" threads. The hard flat washer is my deal because I've seen too many broken lockwashers over the years and then that blows an exhaust gasket when the lockwasher has fallen out of place leaving the bolt loose.
IBWD MIke
Posted: 25 May 2023 at 8:41am |
Thanks, now if I can just remember this if it ever comes up!
