8' Model 40 SC Disc FS |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4842 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Aug 2024 at 6:19pm |
I have this model 40 Snap Coupler Disc Harrow for sale. I have replaced all found worn/missing parts and loose bolts. Field ready ready WD or similar size. I have been using it behind a D10 with a LOT of added front weight and it's a bit light even with all the added weight. It has almost new 20" notched front blades on a wide spacing. The rears are smooth 16" blade on a narrow spacing. This model allows for the gangs angle to be adjusted and I have it set somewhat aggressive, it will tear into sod. All the Bal-Pak bearings are good. I'll sell it for $1200. Located in north central Maryland, not far from Gettysburg, Pa.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3842 |
That would be a great one to have but Maryland is a loooong way from Iowa.
There's probably someone with Allis Express that would move it for you.
Bump
My pulling season is over for this year, it will be starting again in April. I will hold onto it for later delivery or pick up if paid for.
Tim NH ![]() Orange Level Access ![]() Joined: 16 Oct 2012 Location: Lancaster NH Points: 1103 |
Hi Paul, I'm looking for a 8' transport harrow. Is the spacing between the gangs great enough for that on yours. Tim
private reply sent
Could deliver to the Booneville swap meet if paid for
