8' Model 40 SC Disc FS
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: 8' Model 40 SC Disc FS
    Posted: 18 Aug 2024 at 6:19pm
I have this model 40 Snap Coupler Disc Harrow for sale. I have replaced all found worn/missing parts and loose bolts. Field ready ready WD or similar size. I have been using it behind a D10 with a LOT of added front weight and it's a bit light even with all the added weight. It has almost new 20" notched front blades on a wide spacing. The rears are smooth 16" blade on a narrow spacing. This model allows for the gangs angle to be adjusted and I have it set somewhat aggressive, it will tear into sod. All the Bal-Pak bearings are good. I'll sell it for $1200. Located in north central Maryland, not far from Gettysburg, Pa.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 7:56am
That would be a great one to have but Maryland is a loooong way from Iowa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 6:37am
There's probably someone with Allis Express that would move it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2024 at 3:44pm
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2024 at 7:01am
My pulling season is over for this year, it will be starting again in April. I will hold onto it for later delivery or pick up if paid for.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 22 minutes ago at 6:19pm
Hi Paul, I'm looking for a 8' transport harrow. Is the spacing between the gangs great enough for that on yours.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 5 minutes ago at 6:36pm
private reply sent
