720 Wiring to Operate Lawn Sprayer
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 720 Wiring to Operate Lawn Sprayer
    Posted: 16 Oct 2016 at 4:36pm
I want to use my 720 to operate the pump on my lawn sprayer. With the battery in the front of the tractor, has anyone run an electric line to the back of the tractor to make it easier to connect the connections from the lawn sprayer pump to? Am looking for ideas on how to best do this. Thanks, Dave
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 5:55pm
I've done that on at least 2 of my 720s.  On the left hand side of the dash there is a place for another switch.  That's where we mounted the switch and then out under the seat.  We used trailer wiring pigtails for the connection to the sprayer that we have.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:08pm
So, Den, you just ran a line directly from the battery to the switch you inserted in the dash, then on to back under the seat for the connection to the sprayer, if I understand it correctly? Tkx, Dave
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:16pm
On my 720, there is no PTO shaft in it. I just took the wiring from the rear pto clutch switch and added on wire to the rear of the tractor. Used a two prong plug on it and the sprayer wiring. Use the switch on console to turn sprayer on and off. rrhead(SD)
Edited by rrhead(SD) - 16 Oct 2016 at 6:17pm
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:17pm
I do have pto, so probably can't route it that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:11pm
Actually when we installed the switches, we were rewiring the tractors, adding relays, fuses, etc as the original wiring was shot.  I can't seem to find the picture now but it was all installed under the dash.  Most likely a little overkill but I have no electrical problems anymore.  So the power actually came from a newer power location under the dash.  The outlet had both a relay and fuse besides the switch.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 6:35am
Nothin' wrong with installing relays etc. especially when you have to send power a distance. Good practice to use Den! Relays are designed to stabilize power in the system to the load its suppling. This way the load gets maximum power as it should. No voltage drop, no issues.
Steve@B&B
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:46am
Steve, sounds like an opportunity for you to come up with a clean kit, I've been wanting to do the same thing too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 11:48am
I got the wire run to the back of the tractor. Have it connected from a switch I installed in the dash. I'm going to put a fuse in the line under the dash, after the switch. What would be a good size fuse to put in it? The sprayer has a 10 amp fuse in the line before the pump, so I know I need at least a larger one than that, but should I go even larger like with a 30 amp fuse? Tkx, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 9:05pm
the fuse should be to protect the wire... If you ran 12 gauge wire, you can use a 20 amp fuse. If you ran 14 gauge wire you can use a 15 amp fuse. If you ran a 16 gauge wire you can use a 10 amp fuse...  smaller than 16 gauge, you are in trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:33am
ok, that's exactly what I needed to know. Looks like a 15 amp fuse it will be. tkx Steve.
This page was generated in 0.131 seconds.
