720 tiller
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: 720 tiller
    Posted: 18 Apr 2023 at 6:30pm
I recently purchased a 720 tractor and mower. It has a three point hitch and both front and rear PTO. Is the simplicity tiller the only one that with work on that machine? I'm beginning to think so ,because of the PTO speed and odd female spline setup. Any knowledge is welcome and are they available?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2023 at 6:59pm
 I have a 36" 3 point rototiller with a gas engine with recoil start, that I don't use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 5:06pm
The 48” Allis or Simplicity version is the only one that is designed for it. 1,000 rpm pto and only accepts the small spline drive shaft. And they are sometimes difficult to come by. I looked for 6 years until I stumbled across one.
Edited by AC720Man - 20 Apr 2023 at 5:07pm
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 10:04pm
Robbie, it's actually 2000 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 3:15pm
Your correct Brad, I had the 1,000 rpm pto thread on my mind about the 7095. Thanks for correcting me.
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2023 at 4:30pm
I have an absolute tank of a Montgomery Wards/Sears tiller for mine but I've never seen another, as well as an Allis version. The Cub Cadets also had a 2000rpm pto input speed 3pt tiller. As well as the john Deere's.
Edited by Bird76Mojo - 27 Apr 2023 at 4:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 12:29pm
Yes, I was told that the 420 and 430 John Deere used that pto system. Do you know what IH tractor models would use that setup? Or even the number of the IH tiller?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 5:10am
No I do not. Sorry.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 5:18am
982 Cub Cadet, not sure on the tiller model no. Some of the later super garden's may have used the same tiller.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 12:49pm
It's 2000 rpm, but they also turn the opposite direction the std 540/1000 turn.
This page was generated in 0.115 seconds.
