720 sickle mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 720 sickle mower
    Posted: 05 Aug 2019 at 9:38am
Anyone have a right side lift cable for a 720 sickle mower? It is longer than the one for a belly mower. It looks like they are no longer available.
Brian(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2019 at 9:42pm
I've been looking for one also, good luck. Let me know if you find a source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 7:16pm
Not having any luck, no longer available which I really don’t understand. It’s such a needed part, that wears. So why discontinue it? Anyway I am trying to find a cable company that may be able to make one. The lead crimps that I use are not holding up. Came loose again yesterday.
knkrein1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote knkrein1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 7:39pm
I needed to get one for my 80r. I was able to find a place in Taylor Michigan. This is the contact information from one of their cards:
Commercial Group Lifting Products 12801 Universal Dr. Traylor Michigan 48180
phone # 734 947-4000 www.cglift.com Gabe Chavis
Ken R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2019 at 7:56pm
Thank you for the lead
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 11:39am
Before I start making calls can someone tell me the length of the right side sickle mower cable. Hole to hole.
Thanks
Rob
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 5:58pm
My 2 720 sickle mowers are at the Pinckneyville tractor show his weekend and I'm going to Rantoul next weekend but if you do not have the length by the 27th of August, let me know and I will take one off and get you a measurement. Den
Edited by den/southern illinoi - 14 Aug 2019 at 5:59pm
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 8:19pm
Thanks Den, I really need the measurement and since your willing to do that for me I can wait until you get back unless someone else posts the measurement. I measured the left side and it’s 55”. I’m guessing maybe it will be around 60”? Also Den, verify its 3/16” cable. Someone I think posted some time back that it may be a 1/4” cable due to the weight that it has to lift.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2019 at 10:19pm
The cable is larger than the left side.
By the way, don't be afraid to remind me when the time comes...just don't remember everything I need to do.   Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2019 at 5:51pm
A bit of good news today. Brenda at SLI was able to get me the size of the cable and the length eye to eye. It is 1/4” galvanized aircraft cable. 7x9 strand. 64.916” long. One thing I had not noticed before is the end that attaches to the mower is actually a rounded eye instead of the U clip that is generally used. Now I can make some phone calls hopefully tomorrow to see if I can find a vender to make it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2019 at 9:23pm
I would be interested in any information or source that you find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 9:46am
Brian, I went to my local Ace Hardware and picked up the necessary cable and parts to make a cable. It involves swaging method but luckily a friend has the tool. They also sell the tool there. It will be the weekend until I put it together so I will let you know how it works. The good news is I have the measurements and now the supplies. Look up swaging on utube good videos there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:31pm
I’m sorry this is taking so long, so let me fill you in. My friends swagging tool wasn’t the correct size and the local tool stores do not sell one. So I had to order one which wasn’t cheap. Also ordered the special crimps. I have made the round crimp with a rope cable protector that attaches to the mower. Problem now is the tractor end. The U shaped connector that is on the smaller 3/16” cable is not wide enough for a crimp to fit inside, so I will have to have a machine shop make one. Going by in the morning to see if he has time to make one. Will update as soon as I can.
Skipp72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2019 at 2:41pm
Hello everyone, I am new here, but I am in need of this same lift cable for the sickle bar. If a method of attaining one is met I would be interested as well. Thanks
For those interested in knowing, I have an Allis Chalmers 720 with 60" belly mower, the above mentioned sickle bar mower, a front mount 60" snow plow, rear mount cultivator, and the 52" snow thrower.
Daveb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daveb Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2019 at 6:41pm
I made up a couple cables a couple weeks ago not to hard   Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2019 at 9:11pm
Dave, would you have any cables that you would sell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 5:20am
Skip, you have some of the most sought after attachments for these 720’s. Welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 8:57am
Thanks, would love to still find a rottotiller for it as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2019 at 8:58am
Would be interested if you are willing to sell me one.
I tried making one myself, but the crimp joint did not hold up.
Edited by Skipp72 - 13 Oct 2019 at 8:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 8:03pm
Skip and Brian, I will be glad to make both of you one if mine passes my testing. My machine shop called and he has my U brackets made so I am picking them up tomorrow. I should know in a week or so how my crimps hold up at the tractor attachment point. The factory cable had a steel crimp that was pressed on all 4 sides. I can only do the swagging process. Will give an update when I can. Should have no issue at the mower attaching point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 7:11pm
check with Mwells on this site (wellsimplement.com)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2019 at 2:54pm
AC, that would be great, thanks
Let us know how that works out for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 8:20pm
Hey ac720man, any update on that cable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 8:58pm
I did make a cable and it works well. But I had a limited time to do a long term test due to the mowing season coming to an end. Will be glad to go ahead and make you one as long as you understand my limited testing. I have all the confidence it should be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 9:48pm
Robbie, I would interested in one for me. Where in the valley do you live?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 5:06am
I’m in Shenandoah, I will pm you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 7:14pm
I am definitely interested. I am not , however, in any rush, as I would not likely need my sickle bar till around June.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 8:06pm
Skipp I will stay in touch and be glad to make one for you. If you would rather wait until I can continue testing in the spring that is fine with me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 9:02pm
AC thanks,
That would be fine. It will be nice to be able to use the sickle bar again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skipp72 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 1:06pm
AC
Have you had a chance to continue testing on the sickle bar cable yet?
This page was generated in 0.152 seconds.
