720 sickle mower |
Page 12> |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5234 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Aug 2019 at 9:38am |
Anyone have a right side lift cable for a 720 sickle mower? It is longer than the one for a belly mower. It looks like they are no longer available.
Brian(Va) ![]() Silver Level ![]() Joined: 16 Sep 2009 Location: Red House, VA Points: 91 |
I've been looking for one also, good luck. Let me know if you find a source.
Not having any luck, no longer available which I really don’t understand. It’s such a needed part, that wears. So why discontinue it? Anyway I am trying to find a cable company that may be able to make one. The lead crimps that I use are not holding up. Came loose again yesterday.
knkrein1 ![]() Bronze Level Access ![]() Joined: 02 Aug 2016 Location: Gregory, Mich. Points: 73 |
I needed to get one for my 80r. I was able to find a place in Taylor Michigan. This is the contact information from one of their cards:
Commercial Group Lifting Products 12801 Universal Dr. Traylor Michigan 48180 phone # 734 947-4000 www.cglift.com Gabe Chavis |
Ken R.
Thank you for the lead
Before I start making calls can someone tell me the length of the right side sickle mower cable. Hole to hole.
Thanks Rob |
den/southern illinoi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2068 |
My 2 720 sickle mowers are at the Pinckneyville tractor show his weekend and I'm going to Rantoul next weekend but if you do not have the length by the 27th of August, let me know and I will take one off and get you a measurement. Den
Edited by den/southern illinoi - 14 Aug 2019 at 5:59pm |
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
Thanks Den, I really need the measurement and since your willing to do that for me I can wait until you get back unless someone else posts the measurement. I measured the left side and it’s 55”. I’m guessing maybe it will be around 60”? Also Den, verify its 3/16” cable. Someone I think posted some time back that it may be a 1/4” cable due to the weight that it has to lift.
Thanks again. |
The cable is larger than the left side.
By the way, don't be afraid to remind me when the time comes...just don't remember everything I need to do. Den |
![]() A bit of good news today. Brenda at SLI was able to get me the size of the cable and the length eye to eye. It is 1/4” galvanized aircraft cable. 7x9 strand. 64.916” long. One thing I had not noticed before is the end that attaches to the mower is actually a rounded eye instead of the U clip that is generally used. Now I can make some phone calls hopefully tomorrow to see if I can find a vender to make it. |
I would be interested in any information or source that you find.
Brian, I went to my local Ace Hardware and picked up the necessary cable and parts to make a cable. It involves swaging method but luckily a friend has the tool. They also sell the tool there. It will be the weekend until I put it together so I will let you know how it works. The good news is I have the measurements and now the supplies. Look up swaging on utube good videos there.
I’m sorry this is taking so long, so let me fill you in. My friends swagging tool wasn’t the correct size and the local tool stores do not sell one. So I had to order one which wasn’t cheap. Also ordered the special crimps. I have made the round crimp with a rope cable protector that attaches to the mower. Problem now is the tractor end. The U shaped connector that is on the smaller 3/16” cable is not wide enough for a crimp to fit inside, so I will have to have a machine shop make one. Going by in the morning to see if he has time to make one. Will update as soon as I can.
Skipp72 ![]() Bronze Level ![]() Joined: 12 Oct 2019 Location: PA Points: 20 |
Hello everyone, I am new here, but I am in need of this same lift cable for the sickle bar. If a method of attaining one is met I would be interested as well. Thanks
For those interested in knowing, I have an Allis Chalmers 720 with 60" belly mower, the above mentioned sickle bar mower, a front mount 60" snow plow, rear mount cultivator, and the 52" snow thrower. |
Daveb ![]() Bronze Level ![]() Joined: 25 Sep 2009 Location: Charles City IA Points: 46 |
I made up a couple cables a couple weeks ago not to hard Dave
Dave, would you have any cables that you would sell?
Skip, you have some of the most sought after attachments for these 720’s. Welcome to the forum.
Thanks, would love to still find a rottotiller for it as well |
Would be interested if you are willing to sell me one. I tried making one myself, but the crimp joint did not hold up. Edited by Skipp72 - 13 Oct 2019 at 8:59am |
Skip and Brian, I will be glad to make both of you one if mine passes my testing. My machine shop called and he has my U brackets made so I am picking them up tomorrow. I should know in a week or so how my crimps hold up at the tractor attachment point. The factory cable had a steel crimp that was pressed on all 4 sides. I can only do the swagging process. Will give an update when I can. Should have no issue at the mower attaching point.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
check with Mwells on this site (wellsimplement.com)
AC, that would be great, thanks
Let us know how that works out for you. |
Hey ac720man, any update on that cable?
I did make a cable and it works well. But I had a limited time to do a long term test due to the mowing season coming to an end. Will be glad to go ahead and make you one as long as you understand my limited testing. I have all the confidence it should be fine.
Robbie, I would interested in one for me. Where in the valley do you live?
I’m in Shenandoah, I will pm you.
I am definitely interested. I am not , however, in any rush, as I would not likely need my sickle bar till around June.
Skipp I will stay in touch and be glad to make one for you. If you would rather wait until I can continue testing in the spring that is fine with me.
AC thanks,
That would be fine. It will be nice to be able to use the sickle bar again. |
AC
Have you had a chance to continue testing on the sickle bar cable yet? |
Page 12> |
