720 Hydro Filter/ Fluid |
dertz19
Topic: 720 Hydro Filter/ FluidPosted: 18 Aug 2019 at 10:24pm |
Thank you all for the input!!!!
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 17 Aug 2019 at 6:09pm |
I have the WIX51307 installed. Should be same as Napa 1307. It appears to be not as long as the 1068. Also, with 51307, the end is more rounded, maybe allows for more wiggle room. Anyway, it fit with fender in place and as installed I measure .52" clearance. My machine is actually a 620. I do not see an opportunity to have the fenders set further inboard (thereby reducing clearance). If there is an issue with using a 51307 vs 1068, would appreciate a heads up.
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2163 |
Posted: 17 Aug 2019 at 11:19am |
I used Fram PH16 filter. Didn't have to remove the fender. Also, I think I used Dextron III, but would have to go look at the container to verify. Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 17 Aug 2019 at 8:30am |
We have the filters in stock, but if you have a Napa store near by, walk in and ask the counterman for a Napa Gold 1068. You'll have to remove the fender to install it, but its a large filter and it just fits between the fender! Oh, and BTW, Rob is right Dexron II Steve@B&B
Edited by Steve in NJ - 17 Aug 2019 at 8:35am |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5453 |
Posted: 16 Aug 2019 at 9:16pm |
I need to verify but I think I put Dextron II transmission fluid in mine. Any Simplicity dealer should have a filter. Carquest also carries the filter.
dertz19
Posted: 16 Aug 2019 at 11:18am |
Any recommendations on brand/ type, source, etc.?
