72 all crop |
acd21man
Topic: 72 all cropPosted: 15 Jun 2018 at 10:56pm |
![]() I don’t know that the picture worked but we got a 72 all crop college bought it new. I’m on a little vacation at some drag races in ky. But we bought this to combine orchard grass can anyone give me some settings for small seed like orchard grass. |
acd21man
Posted: 15 Jun 2018 at 10:59pm |
![]() I had to do a lot of cropping and it kinda ruined my pictures but I can get more I have the stuff to fix the real |
acd21man
Posted: 15 Jun 2018 at 11:07pm |
Oh and another thing they pulled this thing I guess 50 or 60 miles on the original tires. One blow out right in the drive way. They said this thing pulled perfect
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8474 |
Posted: 16 Jun 2018 at 9:44am |
An operator's manual would be your best friend in this case. I've seen some on e-Bay before, but a forum member might have a good one they'd sell.
acd21man
Posted: 16 Jun 2018 at 2:30pm |
We have some books I think on a 66 I’ll have to look my dad know a lot about all crops. Me not so much but I know it’ll run clean and be good. It’s pretty complete I’ll be home this evening and I’m going to work on it
CrestonM
Posted: 16 Jun 2018 at 2:45pm |
Use your 66 book then. Settings should be the same I would think.
westfork
Posted: 16 Jun 2018 at 6:26pm |
cylinder speed 1600
shelling plate,concaves 1/8-1/4 wind valve 0-1/4 finishing sieve 9/64 These are from the 72 operating manual. I found its a good start. You"ll have to fine tune. You will fine that it is a very good machine. Grease it good. I forget how many grease fitting there are (74)?. But it takes 30-45 minutes once you find them all.
CrestonM
Posted: 16 Jun 2018 at 6:39pm |
Yep, make sure you get all the Alemites greased well since it's been sitting, especially the ones in the hard to get to places. Think of it this way...if it's that hard just to grease it, imagine what it'll be like trying to get in there to replace the bearing.
It also helps to have a grease gun hose that's fairly long for some of the fittings. I'd start with westfork's recommendation of 1,600 RPM on the cylinder, and if you want and conditions are right you can generally dial it down. I think it's more gentle on the grain that way. Not sure if you've been to the Orange Spectacular or not, but in the past they've put out a neat copy of the old "knowledge is power" booklet covering basic operation, adjustments, and troubleshooting on the All-Crops. It's a lot handier in the field than thumbing through the operator's manual. Something else I've found handy when getting everything set is to have a helper drive the tractor while you walk beside the machine with a grain scoop catching material off the shoe. You can then analyze it and check for loss. Once you get it set right, there will be little to no loss, except for maybe some small shriveled kernels once in a while.
Edited by CrestonM - 16 Jun 2018 at 6:47pm |
westfork
Posted: 16 Jun 2018 at 6:54pm |
I used a battery operated grease gun. Worked ok if you remember to charge the batteries. I now use two hand pump guns, one with a long hose and one of those smaller one handed guns. They work very well in the tight spots.
Edited by westfork - 16 Jun 2018 at 6:55pm |
acd21man
Posted: 16 Jun 2018 at 8:59pm |
Thanks guys those settings are those just grass settings and then fine tune it or is that pretty close to orchard grass specs. I turned it on this evening about 30 minutes ago put the reel together someone had the belt tension off that drives the reel. I’m planning to us it tomorrow.
This thing come from Spring Hill test station in TN they bought it knew. I’m excited to try it iv been wanting a nice one |
CrestonM
Posted: 16 Jun 2018 at 9:22pm |
Also, your reel belt in the above photo...it's routed upside down. Here's how it should be. It's a huge "pet peeve" of mine when they are routed upside down. The point of the high-clearance drive is to keep tall crops/weeds from tangling in the chain/belt. I don't know if guys just don't remember how it's supposed to go or they just don't care. Either way, it's like nails on a chalk board to me.
This is a Super 100, which uses a chain drive, but it's routed the same way. ![]() Edited by CrestonM - 16 Jun 2018 at 9:30pm |
westfork
Posted: 17 Jun 2018 at 6:31am |
Those were orchard grass specs out of the model 72 operating manual. Different conditions, dry etc, may require a fine tune. I usually just adjust the throttle. That may be the lazy way, but have found that a little less rpm usually works out.
acd21man
Posted: 24 Jun 2018 at 10:15am |
acd21man
Posted: 24 Jun 2018 at 10:16am |
Little bit of action that evening conditions got hard
But I here is a video of the combine |
acd21man
Posted: 24 Jun 2018 at 10:25am |
http://youtu.be/Q_cpZiUIF9o
Edited by acd21man - 24 Jun 2018 at 10:25am |
