7080 |
Post Reply |
iamace
Bronze Level Joined: 24 Apr 2013 Location: Pa. Points: 8 |
Posted: 15 Oct 2019 at 6:37am |
I guess I need to take off the injector pump as I still cannot get my tractor to start. Must I line up some timing marks or just remove?, thanks.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4767 |
Take small rectangle cover off the side of pump near the name tag, right below the shut-off lever. Turn the engine by hand until the marks line up, should be close to 22* BTDC. If near 22 on damper, but nothing in pump window, turn it one turn and watch once close to 22 again. Once timed, remove the 4 bolts holding the gear. Lines, linkage, and then the bolts that hold the pump on come in from behind where the gear was. Pretty simple job, just may sound complicated at first. Good luck!
Orange Level Access Joined: 12 Sep 2009 Points: 19504 |
Stuff rag inside the timing cover so when you drop a flat washer from a pump mounting bolt it doesn't go all the way down into the oil pan...………………...
iamace
Thanks men for the replies, I'll give it a shot.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
It seems intimadating, but its not,, just remember how you you remove things and reassembele it
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
Goes without saying but,do not turn engine with pump off!
Post Reply | |
