7080
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=165048
Printed Date: 27 Apr 2024 at 8:38pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 7080
Posted By: iamace
Subject: 7080
Date Posted: 15 Oct 2019 at 6:37am
I guess I need to take off the injector pump as I still cannot get my tractor to start. Must I line up some timing marks or just remove?, thanks.
Posted By: injpumpEd
Date Posted: 15 Oct 2019 at 7:15am
Take small rectangle cover off the side of pump near the name tag, right below the shut-off lever. Turn the engine by hand until the marks line up, should be close to 22* BTDC. If near 22 on damper, but nothing in pump window, turn it one turn and watch once close to 22 again. Once timed, remove the 4 bolts holding the gear. Lines, linkage, and then the bolts that hold the pump on come in from behind where the gear was. Pretty simple job, just may sound complicated at first. Good luck!
------------- 210 "too hot to farm" puller, part of the "insane pumpkin posse". Owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors. stock rebuilds to all out pullers!
Posted By: DrAllis
Date Posted: 15 Oct 2019 at 7:38am
Stuff rag inside the timing cover so when you drop a flat washer from a pump mounting bolt it doesn't go all the way down into the oil pan...………………...
Posted By: iamace
Date Posted: 15 Oct 2019 at 4:13pm
Thanks men for the replies, I'll give it a shot.
Posted By: DougG
Date Posted: 15 Oct 2019 at 6:47pm
It seems intimadating, but its not,, just remember how you you remove things and reassembele it
Posted By: SteveM C/IL
Date Posted: 15 Oct 2019 at 8:27pm
Goes without saying but,do not turn engine with pump off!
