7080 Puller
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: 7080 Puller
    Posted: 04 Jan 2013 at 7:48pm
thinkin of building a 7080 puller, how light could i get by stripping unessential parts?  like 3pt, cab, hyd.  fuel tanks, also what about clutch and flywheel setup?   was thinking 3000 rpm and a fuel setup from Inj Ed,  nothin wild, just want to go out and have sum fun against the green and red boys
Cowboy UP
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2013 at 8:20pm
im not a puller but i do have a question for you.   wouldnt you have alot more weight from the heavier axles and planetaries on a 7080 than say a 7030-40 and essentially the same engine?  and with the power being put through some of the earlier and smaller tractors, will those heavier components be required for what you will be putting out engine wise? i guess you could swap the side panels Big smile
Edited by CAL(KS) - 04 Jan 2013 at 8:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2013 at 8:30pm
Cal, Good question, My reason for a 7080 was, i could get one cheap, and thought a intercooler would be good
Cowboy UP
richfarmsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote richfarmsystem Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2013 at 5:50pm
itercooler can go on any 7030 and up. advantage to using 7080 is heavier clutch pack in pd. same as a 7580. if you want to use it though, convert it to electric like a 8000
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2013 at 9:30pm
Give up !   I have a 7080 and can tell ya it's 14,000 lbs with no 3pt ? I took it over to elevator and weighed it with same idea u have. Once the lard ass hit the scale I parked it . Engine is cool tho so I'm saving it if I can't get my 8010 llss to work right .
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2013 at 6:20pm
Thats the thing with the 7000 series for pullers , they are so heavy to begin with - theres 2 around here not sure if they are true 7080,s tho pulling in the 8500 lb class
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2013 at 6:33pm
Just decals or hood swap is what I see takes place. The one I have is in good condition just never use it . But it's got a monster rear section! By the way I have zero weights on it and no chloride. 14 k ! Never work unless 11 k or 12 k class .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2013 at 11:49am
I hear ya, these have aluminum wheels, been truely gutted in the tranny, finals ground down, tube frame etc, and all that jazz , id personally stick to the One Hundred series!
This page was generated in 0.116 seconds.
