7060 shifting
Message Reverse Sort Order
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 shifting
    Posted: 10 Mar 2010 at 10:07pm
Theres a horse shoe clamp behind the left console panel. You can loosen the nuts on the backside and slide it forward to adjust for wear in the linkage. At higher throttle you may have more pump pressure helping the trans. brake.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:42pm
Could be a stretched clutch cable, the brake engagement is the very last thing during pedal travel, sometimes it you push the pedal real hard youll get more brake action. Then the cross shaft bushings on top of the clutch valve will wear and cause the valve not be pulled out enough to make the brake work good.  Take the left filler plate out below the hood extension, youll be able to see it work then, also the ball joint ends get loose and can break.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:16pm
We have a 7060 power director that the gears will want to clash sometimes when shifting.  This happens on both the high low range shift on console, and the 5 gears on the transmission, oddly enough it seems to be worse at idle or lower engine speeds than at higher throttle. This is fully stopped with the clutch fully depressed. any ideas??
This page was generated in 0.057 seconds.
