7060 remotes
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 remotes
    Posted: 06 May 2011 at 1:18pm
 I am trying to speed my hydraulic remotes up on my 7060. Ive turned the dial under the seat but they still arent as fast as I think they should be. Is there anything else that could need adjusted or could be modified?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 3:03pm
The handle under the seat is for only 1 set of remotes,the other is adjusted from behind the cab,refer to manual.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:18pm
Im actually adjusting them from behind the cab since I pluged off the holes under the seat. I just wondered if there is something else that could be causing them to operate so slow. My 7050 is faster than this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:31pm
The LONG side of the roll pin handle needs to be straight down on ALL valves (2 or 3).  If it's a black belly tractor, remove the 3/8" stop bolt that the hydraulic levers hit inside the console to give them more stroke....linkage gets worn and stroke gets limited to the raise side.
