7060 pto
Les[wcmo] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les[wcmo] Quote  Post ReplyReply Direct Link To This Post Topic: 7060 pto
    Posted: 28 Nov 2010 at 7:55pm
  I will be putting a adaptor on, going from small 1000 to large 1000 size , will 6 grade 8 - 7/16 bolts hold the torque .  Any other options?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 1:20am
I would say so, Theres only 6 bolts holding the shaft in from the factory. My 7060 has the small 1000 I have a 540 adaptor on it, I dont use the power that its putting out (210hp) but I have never had a bit of problem with it
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 7:07am
you could install a dual speed pto that is safer
