7060 hydraulic remote outlets
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hydraulic remote outlets
    Posted: 11 May 2025 at 8:25am
Are the outlets on a 7060 able to be repaired for leaking? I've not taken one apart. New outlets are over $100. Thanks.
Part time farming with a 1980 7060 and 1984 F3 hydro.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 9:34am
You can put new o rings in them. They may stop the leak they may not.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 10:33pm
New orings fixed one of my 8070s that was making a mess at the connection. My other 8070 has the lever lock outlets and one is starting to make a mess so I think I'll try some new orings on it. Not sure that's where it's leaking but orings are cheap and easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 11:17pm
Think it’s 255040 Oring kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 11:14am
To do the o rings, how does the remote come apart, please?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 12:58pm
If its leaking where the tip for the implement goes in theres no need to take anything apart. I take a pointy pick and get the old oring out and work the new one in
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 8:14pm
Thanks everyone, I'll try the repair and see what trouble I get in to.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 8:40pm
Do they leak all the time, or only when you have an implement hose plugged into them? The o-ring seals the male tip to the female coupler body. Your coupler tips could also be damaged or rusty where the o-ring should seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:37pm
I have one leaking while hooked up only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 7:21am
Most likely the o-ring is the problem. Inspect the tip for damage on the sealing surface. You could also switch hoses to see if it still leaks at that coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 9:08am
Thanks Lynn, I didn't realize that there's an external o ring, I will replace it and check the connection surfaces.
