7060 hydraulic remote outlets |
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 770 |
Topic: 7060 hydraulic remote outletsPosted: 11 May 2025 at 8:25am |
Are the outlets on a 7060 able to be repaired for leaking? I've not taken one apart. New outlets are over $100. Thanks.
Part time farming with a 1980 7060 and 1984 F3 hydro.
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 790 |
Posted: 11 May 2025 at 9:34am |
You can put new o rings in them. They may stop the leak they may not.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8750 |
Posted: 11 May 2025 at 10:33pm |
New orings fixed one of my 8070s that was making a mess at the connection. My other 8070 has the lever lock outlets and one is starting to make a mess so I think I'll try some new orings on it. Not sure that's where it's leaking but orings are cheap and easy.
Mikez
Posted: 11 May 2025 at 11:17pm |
Think it’s 255040 Oring kit
Ben (MI)
Posted: 12 May 2025 at 11:14am |
To do the o rings, how does the remote come apart, please?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 664 |
Posted: 12 May 2025 at 12:58pm |
If its leaking where the tip for the implement goes in theres no need to take anything apart. I take a pointy pick and get the old oring out and work the new one in
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Ben (MI)
Posted: 12 May 2025 at 8:14pm |
Thanks everyone, I'll try the repair and see what trouble I get in to.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2440 |
Posted: 12 May 2025 at 8:40pm |
Do they leak all the time, or only when you have an implement hose plugged into them? The o-ring seals the male tip to the female coupler body. Your coupler tips could also be damaged or rusty where the o-ring should seat.
Ben (MI)
Posted: 12 May 2025 at 9:37pm |
I have one leaking while hooked up only.
Lynn Marshall
Posted: 13 May 2025 at 7:21am |
Most likely the o-ring is the problem. Inspect the tip for damage on the sealing surface. You could also switch hoses to see if it still leaks at that coupler.
Ben (MI)
Posted: 13 May 2025 at 9:08am |
Thanks Lynn, I didn't realize that there's an external o ring, I will replace it and check the connection surfaces.
