7060 cab noise
Message Reverse Sort Order
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: 7060 cab noise
    Posted: 09 May 2010 at 3:03am
ac used big foam blocks, different sizes, yes...the mice loved them too. i took mine out, and there is a little more noise, but not that much. not sure what we can use that the critters won't find likable.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 11:30pm
 When these tractors came out did they have anykind of insulation in the dash to quiet it down in there? When i got the tractor it had fiberglass insulation shoved in there and the mice loved it, and were chewing the wires up so i took it out. I know its going to be loud especially with the straight pipe but if I wanted to you couldn't even here the radio in it. Also does anyone know where you can buy a new or used handheld tachometer?
