7060 4 wheel drive 4 sale
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Topic: 7060 4 wheel drive 4 sale
    Posted: 28 Mar 2011 at 8:33pm
sale-7sben-2290350313@craigslist.org   7060 4 wheel drive for sale.  no photo not mine  CL rochester NY
Edited by kip in cny - 28 Mar 2011 at 8:34pm
160 CA 920diesel 5020 HD-3
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:37pm
Sounds fishy, and no pics huh?
Still in use:
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:32am
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 9:33am
Okay all of you powershift mechanics. What would it cost to go through the transmission? $10,000 if it was serious?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:13am
There's a chance that all it needs is to have the shift valve taken apart and cleaned.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 11:37am
yah, mine had the detent pin broke off.  I machined a new one and cleaned up the valve body. worked perfect.  anyways... my dream come true!! even if it is hydrolic front wheel drive!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 1:13pm
It would be neat for someone on the page to have.  Its the 2nd one I know of in NY.   I think the price is a bit high still but maybe cash might talk.
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 1:53pm
kip, do you have any pictures.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 1:59pm
What's the deal with "Mudhog" 4 whl drive, was this a decent arrangement??
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 5:03pm
 WOW,  this must be it, one of the long lost prototypes 7000 series with Bush Hog FWA.
If it wasn't so far away id be hauling today. Some collector on here better pick this up before it gets lost again or ends up on road construction crew pulling a packer and beats the heck out of it.
ALLIS CHALMERS "The color is orange"
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 5:06pm
bush hog??   my mind must on other things.  Mud Hog duh,   i think we had one of those on massey combine years ago.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 6:21pm
how did they run the hydraulic axle?  they require more GPM than the pump is capable of don't they?  surely they didn't run it through the a spool valve.  and it would only match maybe one or two gears.   WE have two of those axles on an F2 and L2 but they split the flow from the hydro.  this is gear drive.   i'm really curious how they powered it and how it worked.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:31pm
I'd like to have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 11:38pm
It was a long time ago, and sales did most of the work with Mud-hog, so I could be wrong.  It was driven off the normal hydraulic pump (the 7000 series had a better hydraulic system then a lot of tractors of that era).   As the name "Mud-Hog" implied, it was more of a way of working in mud than improving normal field performance (it probably hurt that).  I think it was set up for slower speeds and when you were in a fast enough gear, it just free-wheeled.  The place that I went to check on the prototype was in the vegetable field of Florida.  They wanted to pull the vegetables out when they were ripe or they were needed on the market regardless of the mud or not.  They had a field rotation worked out that would provide carrots (for instance) on a continuous basis.  If they couldn't get the carrots out, and then replanted, it messed up their rotation.
Mark
GTH-L Simplicity
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 6:16am
That looks like something that should have been built at the factory!!
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 0.112 seconds.
