7050 hydraulic issues
Wilczynskijr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilczynskijr Quote  Post ReplyReply Direct Link To This Post Topic: 7050 hydraulic issues
    Posted: 29 May 2023 at 9:37pm
Tractor has has issues sense I got it. Put new cables on it. It has hydraulic fluid. Everything works just remotes only work half the time. And most the time you.misy move lever around to find sweet spot and they are very slow and touchy. I've tried adjusting and seems like nothing changes.almost seem to surge for hydraulic fluid. Are my valves bad or is it the pumpm itslef?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 9:56pm
How does the power steering work ??? What exactly have you been adjusting ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilczynskijr Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 10:38am
Power steering is not 100 percent.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 11:14am
Everything begins with the power steering pump. You've inherited the problem and have no idea when the hydraulic filters were serviced last. So, assuming the oil level is truly up into the TOP sight glass, I'd be changing the two hydraulic filters under the rear end. Make sure the left filter has the screen transferred from the old filter if it is even in there. If the screen is missing, that may well be your problem. Use only AGCO filters !!!! Get an owners manual, as changing those filters for the first time is a chore. Do NOT swap filter covers left to right. Right filter goes in spring first. Left filter goes screen in first. Until this area is 100% correct, you cannot diagnose what is going on with certainty.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2023 at 9:35pm
Sounds like you also have a lot of worn out linkage.                MACK
This page was generated in 0.191 seconds.
