7045 pto engagement
Rad21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rad21 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 pto engagement
    Posted: 26 Jul 2019 at 3:30pm
Regarding my 7045, in the past, by barely moving the pto lever it would begin to engage smoothly. Now, you are almost at the end of the lever travel before it engages abruptly. Is this an indicator of low psi on my pto valve? I believe the pressure should be around the 400-600 range? Is there a pto clutch? I do not own a manual. Thanks for any advice
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 4:57pm
It sounds like a cable adjustment problem or a loose rod end on the cable.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 9:01pm
Check cable for inner wearing through outer at bend in cable.     MACK
