Print Page | Close Window
7045 pto engagement
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=163125
Printed Date: 03 Sep 2025 at 7:19pm
Topic: 7045 pto engagement
Posted By: Rad21
Subject: 7045 pto engagement
Date Posted: 26 Jul 2019 at 3:30pm
Regarding my 7045, in the past, by barely moving the pto lever it would begin to engage smoothly. Now, you are almost at the end of the lever travel before it engages abruptly. Is this an indicator of low psi on my pto valve? I believe the pressure should be around the 400-600 range? Is there a pto clutch? I do not own a manual. Thanks for any advice
Posted By: Joe(TX)
Date Posted: 26 Jul 2019 at 4:57pm
It sounds like a cable adjustment problem or a loose rod end on the cable.
Posted By: MACK
Date Posted: 26 Jul 2019 at 9:01pm
Check cable for inner wearing through outer at bend in cable.     MACK
