7040 Piston Pump Seal/Gerotor Pump
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Piston Pump Seal/Gerotor Pump
    Posted: 16 hours 25 minutes ago at 7:27am
Good morning. Working on replacing the gerotor pump seal and pump drive shaft seal on a 7040. I'm seeing in the parts breakdown that some piston pumps have shaft seals, some don't. A preliminary look at my pump says it could have a seal, but currently doesn't. Should it? I'm also wondering about gerotor pump oring. I'm not talking about the 2 identical orings on the diameter of the gerotor pump, but the oring that sits on the face of the gerotor housing. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 32 minutes ago at 2:20pm
Piston pumps on tractors never had a shaft seal. Combine pumps did.  If there is a gerotor pump Oring, it needs to be there. Wrap the gerotor pump shaft splines like a barber pole, one layer with slight overlap with good black electrical tape. Oil the tape and slide the seal over the splines now without damaging the seal.
