7040 Manuals? Parts?
joelsplace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Manuals? Parts?
    Posted: 14 May 2019 at 3:36pm
I just hauled my 7040 home last night.  It needs a lot of work.
I need manuals, radiator, water pump, condenser, compressor & hoses, filters, several pieces of glass & gaskets for the cab, hinges and hardware for one side glass, center exhaust manifold, muffler etc.
The plan is to change filters, oil and fuel and see if it will run before buying all the other parts I know it needs.
Best place to get things in my list?  Ebay was suggested for the manuals.
Should it start without ether?  Is it just needed below a certain temperature?
Suggestions?
Are the sleeves thin enough that it needs anti cavitation additive in the coolant?
Is the Wix catalog accurate on the filters?
Thanks!
Edited by joelsplace - 14 May 2019 at 3:37pm
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 7:27pm
Engine oil  filters are 74037047 for the tall filters or 74035556 for the short oil  filters , tractor takes two. fuel filer is 74024223 old number or 71367687 is the new number.
Air filter is 7066767 outer. . These are AGCO part numbers .
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 7:39pm
Check your pm's
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 8:52pm
No ether, or very,very little
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 8:54pm
No ether until it's blowing smoke out the stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:47pm
What is very, very little? 1/2 second spray?
Where do I get replacement cans? I'm guessing it's a factory system the way it is plumbed in.
Thanks!
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:52pm
Thanks!
According to my 7010 manual the factory system delivers a metered amount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:55pm
Ok so one squirt of whatever the system delivers?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 5:26am
You can use the on line parts books at AGCO Parts Books. Sign in as a guest user.
In the same box as the sign in you will see the link for AGCOpubs.com as well. Click on that link and it will take you to their store where you can purchase manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 7:01am
Great info. Thanks!
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 10:05pm
I purchased a 185 with 500 loader from an older couple.  They had no idea where the manuals were.  Went to see Lyle Hunsley south of Waverly, IL.  Lyle's a former A-C dealer who has a shed  FULL  of parts & pieces.  He went to a filing cabinet & came back with a brand new manual for my 185.  Lyle's phone # is 217-691-8302.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 10:29am
Original manuals can be found cheap on e-bay.  For everything else, stay away from e-bay!
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 6:49pm
Other AC parts on eBay are bad?
1975 7040 w/Power Director
