7040 injection pump
Hurt Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurt Farms Quote  Post ReplyReply Direct Link To This Post Topic: 7040 injection pump
    Posted: 26 Mar 2012 at 8:36pm
i just bought a 7040 and when u idle it down it goes dead,so i took the top off the pump and cleaned the meteing valve and just about everything else in there.i also took the kill solenoid out(must've came off a combine).i pulled a disk the next day and it still goes dead when u idle down and doesnt pull worth a crap.so do i need to have my pump built or is there anything else i can do?who's the best pump rebuilder?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:02pm
Check all the lines and make sure you don't have a restriction on the inlet line, or an air leak. I can rebuild it if needed. thanks, Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurt Farms Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 10:21pm
how much,where u located,what kinda warranty,how much will u turn it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:23am
I'm in North central IL. I will set it how you need it. PM me for more details.
