7040 hydraulic actuation cable R & R
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydraulic actuation cable R & R
    Posted: 10 Nov 2023 at 4:16pm
What are the do's and dont's on this job.
Cables are $215 each.
Hope I can save one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2023 at 5:17pm
Knowing which cable you have is the first thing. Small or larger diameter, Especially on the remote levers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2023 at 7:40pm
It is a later serial number 7040.
Sandy Lake looked it up per the serial number.
My question is do I just remove the side panel on inboard side of console ?
And
Which bolts/nuts if any do I leave in place ?
Thanks in advance
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2023 at 8:39am
Taking the side panel off isn't really necessary. Remove the three long screwdriver head bolts that hold the two halves of the top cover plate. Get the cable disconnected from the rear of the tractor at the hydraulic valve stack. You can either disconnect the cable ends from the levers in the cab or pull the old cable into the cab and unscrew it from the end on the lever. Open the rear window and let the cable go out the window while you unscrew it from the end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2023 at 9:12am
THANKS
Exactly the info I was hope to get
You guys are AWESOME !
Wish me luck. That will be one of my many projects today.
