7030 2 speed
Boldt220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boldt220 Quote  Post ReplyReply Direct Link To This Post Topic: 7030 2 speed
    Posted: 08 Jul 2016 at 11:57am
Anyone have any idea if you can beef the two speed button shift with the power directors I wanna use it at around 500 hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:21pm
If it were mine I would not use it /shift it unless definitely needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boldt220 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:58pm
Can you do anything to of like a t/a on an ih. We have messed with 220 and d21's but never one of these. We have a timed pull around us were they don't add much weight to the sled and it's how fast you go between the two timers. They have found a way to get the dual power and t/a and the over unders in the Oliver's to hold I would think you could do the same with that
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 3:30pm
The problem with a power director trans is there's a neutral in between the speeds. If there's a way to adjust our the neutral you should be able to shift
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 3:52pm
It can be done. Starting with a 7580 clutch assembly is a good idea, as there are more discs in low and high. Torque limiter has to be bolted solid someway is the first step.
This page was generated in 0.077 seconds.
