7020
CDN 400 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Topic: 7020
    Posted: 02 Apr 2024 at 12:34pm
just trying a picture.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 2:08pm
CDN 400, congratulations on uploading your 7020 photo. Good looking AC tractor. What year is it? PD or PS trans? Which farm jobs does it do?
Edited by AC7060IL - 02 Apr 2024 at 2:09pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 4:58pm
[QUOTE=AC7060IL]CDN 400, congratulations on uploading your 7020 photo. Good looking AC tractor. What year is it? PD or PS trans? Which farm jobs does it do?
I just bought it in December but it's a 1980 PD transmission. Its just going on light duty planting ,discbine and 575 New Holland baler. I've had it in the shop for the last couple months working on it and doing some upgrades. I have more pics but I want to try and make them a little bigger.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:16pm
try again
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:38pm
Looks like a nice straight tractor.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:40pm
more
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:42pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:44pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:45pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:55pm
If anyone sees anything wrong or shouldn't be done please let me know. What I done was relocate the precleaner under the hood and added a straight pipe just for improved visibility for planting. Added a mount for monitors and a trailer plug with signal lights. Went from 20.8's to 18.4's ,painted all the rims and cast centers ,painted the inside of the cab and new cab kit. New hytrans and agco filters in the rear and fixed the ac. I also cut a hole in the back of the cab for monitor cables. Only thing I can't find is a set of 9 bolt hubs for axle duals. If we like it we will paint it all next winter.
Edited by CDN 400 - 02 Apr 2024 at 5:57pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:58pm
Very nice. I did the same as you for the trailer plug wire. I am guessing the pie shape plug is to pass a monitor plug and harness through for implements? Neat idea
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 6:00pm
Yes sir its cut where I marked it with my sharpie.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 6:09pm
dp7000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 9:24pm
Super nice. You’ve done a great job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 11:12pm
Get a tiny little chain at hardware store and zip tie it to fill tube plug and one of those control cables. That way you won't drive off with it just laying there after adding and "plant" it. New is stupid $$$. No luck at salvage yards.
Edited by SteveM C/IL - 02 Apr 2024 at 11:13pm
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 9:14pm
Done that before luckily for me it stayed where it was at miraculously.
