7020 pto |
jjpetrich ![]() Silver Level ![]() ![]() Joined: 06 Sep 2011 Location: Marshall, MN Points: 137 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Sep 2011 at 11:06pm |
Back pto has a little play in it. just wondering if its a bearing that was going out or could be a bigger problem.
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Just a couple stupid questions, are all the bolts around the outside edge tight? Where the flanges clean before bolting it up? Define a little? all shafts and bearings have a very small amount of play in them. are we talking thousands, or tenths of inches of play, and which dirrection are you talking? Up and down, or in and out?
Still in use:
bolts are all tight and everything is clean it moves about a 1/4 of an inch side to side
sure sounds like a bearing is out, or a really badly worn shaft. It must be leaking oil too?? A 1/4" is way too much
Still in use:
