7020 3 point pin size
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 7020 3 point pin size
    Posted: 14 Jun 2010 at 3:30pm
anyone know the pin size on a 7020 3 point? I believe they are 1 1/8 on all three can anyone tell me for sure. thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 3:34pm
That tractor should have a category 2 3pt hitch set up, in which case, you will have 1-1/8 inch lower links and a 1-inch upper link.  This link should help:
http://en.wikipedia.org/wiki/Three-point_hitch
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 3:52pm
tractor data list it as catagory 3/2  so I still don't know for sure. I thought there was somthing different about it than the strait cat.2 that is on the 190
Allis Express
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 3:59pm
My 7020 is a cat. 3.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 4:31pm
Its Catagory 3, the upper pin is a little smaller than the lower two. I dont remember the size right off hand.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 5:09pm
Should be cat.3,use bushings for cat.2 implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 5:25pm
Well, I learned something new today.
Hurst
5800 Hours
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 5:29pm
that is correct ..same as my 7040
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
