7010 powershift hyd filter light?
Message Reverse Sort Order
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Topic: 7010 powershift hyd filter light?
    Posted: 13 May 2010 at 12:52pm
Could be the pickup on the outside of the filter isnt working,  those used to be spendy.  Seems there was always a little trouble gettin the lite to be off. I dont know if the sender was to sensaitive or the spring that holds the filter up in the canister is to weak.  Good luck.
mnziggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnziggy Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:28pm
only trans pressure light should come on below 1800 rpm. Either new filter is bad or sensor could be defective. There a two magents is plastic valve that fits on top of filter, when filter is plugged, oil pressure forces filter down and moves magnets away from sensor in filter head. Check to make sure magnets and holder is in good shape.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:55pm
our 7040 light used to come on at low rpm,s ..then it came on all the time .. thru it all the tractor worked fine ..if it was my tractor i would put a new filter on it each year ..keep an eye on oil level ..and not worry .. of course you could drain the system every 5 yrs or so  as moisture could get to be an issue ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Clay Bragg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Bragg Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:45pm
light is on at 2300 rpm filter light should never be on should it?trans preassure light can be on at less than 1500 if im not mistaken
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 2:51am
what rpm does the light come on or go
 off? light should be on under 1800 rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Bragg Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:23pm
light comes on when working in low range 5 6 gear switched to high range 1 gear no light.changed fluid and filter this spring.any ideas?
