7000
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: 7000
    Posted: 22 Jun 2017 at 10:13pm
Have an ac 7000.  Everything fine accept when you put it in reverse, there is noise i think in the rear end..  Any thoughts on what we maybe looking at.  Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2017 at 10:23pm
Tooth bad on one of three reverse gears. Reverse directly behind park causes a problem with reverse gears. Operator pushes clutch down, pulls shifter from park to reverse, transmission has not stopped yet and gears clash, causing damage to reverse gears.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 8:20am
Thanks Mack
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 6:45pm
I believe you can repair it without splitting it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:06pm
The only gear that can be replaced without a split is the sliding gear. MACK
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:42pm
If it's the sliding gear, which was made out of softer metal, I believe, than the other two gears, you need to pull both the shifter top and the rear end cover, as the shaft has a retainer that is bolted on the differential side. The new gear will need to be honed to the size of the shaft, so you will need to take them to a machine shop, all assuming that is your problem. The gear is available aftermarket. The other gears are on your transmission shafts. I know the countershaft gear is actually machined into the shaft itself. I can't remember about the top gear.
Hurst
1979 Allis Chalmers 7000
5800 Hours
