7000 smokes
tnboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnboss Quote  Post ReplyReply Direct Link To This Post Topic: 7000 smokes
    Posted: 27 Dec 2018 at 2:00pm
my 7000 smokes black when under load. pump has been rebuilt 7 yrs ago, starts good has little to no blow by,uses very little engine oil leaks a little from front main. Also seems a little under powered, spends its days on sprayer or baler. So where to start looking? pump,injectors,turbo,timing? Has been thus way for several yrs.not getting worse but would like correct so it doesn't look like the tractor pull every time I go uphill. thanks for any advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 3:25pm
I'd hook to something and pull the snot out of it , get some good heat in the engine, deffintly listen and make sure the turbo spinning good
Edited by DougG - 27 Dec 2018 at 3:26pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 4:44pm
put a pressure gauge in the intake manifold and check turbo boost pressure! This sounds like a missing plug or blown intake manifold gasket or hose issue to me. You are losing boost pressure to the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 7:13am
On that tractor, you should be seeing 12 to 14 psi boost pressure with the throttle wide open and pulling a heavy load. So, don't use a 100 psi gauge. try and get a 20 or 30 psi gauge for accuracy.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 9:02am
Have the injectors been checked? When I rebuilt my 7000 (several years ago), only one injector checked out ok. The other 5 were just dumping fuel in and I wasn't getting a good burn and black smoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 10:23am
one other thing, does this happen to have Ambac/Bosch injectors? Injection line goes in the top? If so, they get installed the wrong direction quite often. The return line is supposed to be toward the valve cover, not toward the exhaust manifold. Them being installed wrong makes a lot of black smoke and lack of power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnboss Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 4:30pm
Thanks for the replies, checked boost pressure at intake manifold with tractor wide open had nothing. took turbo off and something chewed up the impeller, it did turn free. so ordered new turbo. the injectors pressure comes in the side and return out the top so not that injector,ran right out to look though. hopefully new turbo will fix or will have to look elsewhere. also ordered the elbow that goes to muffler as was totally rusted. is there a gasket between elbow and turbo book not showing 1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 4:51pm
well, a junk turbo will cause a no boost issue, and will give the symptoms you had. While working on it, look over the manifold, and blown gaskets to make sure there's no other leaks. The elbow does have a gasket, it may come with the new turbo. Would be fine without one using new turbo and new elbow, both smooth and flat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 6:05pm
Running the tractor wide open throttle sitting still isn't really a test. It will not have very much boost that way. You'll have to take it down the road up a hill in road gear with a load behind it to get any kind of boost. I'm not saying you may not have a bad turbo, but you have to test differently for good data.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 8:40pm
In response to Doc's boost gauge, If you can find a N series for parts combine most if not all had boost pressure gauges installed from the factory and make a handy diagnostic tool. Good Luck, Mike
This page was generated in 0.069 seconds.
