7000 front end
weldfixer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weldfixer Quote  Post ReplyReply Direct Link To This Post Topic: 7000 front end
    Posted: 28 Mar 2011 at 8:31am
I want to put a 7060 front end on a 7000 with a loader .  Can I do so by sliding out pivot shaft and putting that heavier axle in I know frame width wont match that is why I leave big bolster in place on frame rails and slide big shaft forward any body try this ? John
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 9:17am
John i think the pivot pin on a 7000 is smaller then tha 7060's may have to get some bushings to make up the differance Niel
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 10:27am
One thing I noticed on my 7000 with a HD front end is that the steering cylinder shaft is much smaller in diameter than a 7030 I saw in a salvage yard once.  I'm not sure if this is a maroon belly/black belly change or if the bigger 7000 series got different steering cylinders.  If this is the case, it could steer kind of funny if the steering motors were different to account for the different fluid volumes when steering in each direction.
Hurst
1979 Allis Chalmers 7000
5800 Hours
