$70 snap ring XT
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: $70 snap ring XT
    Posted: 13 Jan 2016 at 10:17pm
While checking end play in transmission  counter shaft  I discovered excessive play, manual says you can replace snap ring with a thicker snap ring
for example #70244155 snap ring is .110 thick and snap ring #70244154 is .107 thick and the existing one is .104 thick.
AGCO price on this part number is $70 any other suggestions?
Edited by Beirnesy - 14 Jan 2016 at 7:58pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 10:32pm
You shur u got the right gamers for the shaft there there diff shift in a 190 . And there is longer and shorter ones and .diff bearing on them to .
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 5:22am
maybe some place like IBT bearing
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 6:24am
yeah, i think id go to motion ind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 6:26am
ANY bearing supply place sells them!  I bought 3 for the 'used-abused' rear blade.Cames out of the store with 3 and change from a $20 bill !
If you have the old one it's simple, they just measure and lookup in computer.Might take a day or 2 to get from their warehouse though.
Jay
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 7:47am
I have 3 boxes of Snap rings for the rear and trans .All new in bags .Be a few days before I can check #'s .
nonetheless ,still dead.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 10:38am
Jay
I think the problem here is the thickness.
ALLIS EXPRESS!
This year:
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 10:47am
did this on my D19, just took out the snap ring and made shims till I got the correct clearance, then reused the original snap ring.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2016 at 12:28pm
I did what Dan said.
It's important to remove the end play to obtain the spec, as those are tapered-roller bearings. IIRC, I made it zero on my D17sIV.
Also, note that one side of the snap-ring usually has a sharp edge on the OD.
The ring should be installed so that that side is toward the open end of the transmission.
This page was generated in 0.111 seconds.
