$70 snap ring XT |
Beirnesy
Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Topic: $70 snap ring XTPosted: 13 Jan 2016 at 10:17pm |
While checking end play in transmission counter shaft I discovered excessive play, manual says you can replace snap ring with a thicker snap ring for example #70244155 snap ring is .110 thick and snap ring #70244154 is .107 thick and the existing one is .104 thick. AGCO price on this part number is $70 any other suggestions?
Edited by Beirnesy - 14 Jan 2016 at 7:58pm |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
8070
Posted: 13 Jan 2016 at 10:32pm |
You shur u got the right gamers for the shaft there there diff shift in a 190 . And there is longer and shorter ones and .diff bearing on them to .
johnkc
Posted: 14 Jan 2016 at 5:22am |
maybe some place like IBT bearing
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
corbinstein
Posted: 14 Jan 2016 at 6:24am |
yeah, i think id go to motion ind.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 14 Jan 2016 at 6:26am |
ANY bearing supply place sells them! I bought 3 for the 'used-abused' rear blade.Cames out of the store with 3 and change from a $20 bill !
If you have the old one it's simple, they just measure and lookup in computer.Might take a day or 2 to get from their warehouse though. Jay |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 14 Jan 2016 at 7:47am |
I have 3 boxes of Snap rings for the rear and trans .All new in bags .Be a few days before I can check #'s .
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 14 Jan 2016 at 10:38am |
I think the problem here is the thickness. |
ALLIS EXPRESS!
This year: |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 14 Jan 2016 at 10:47am |
did this on my D19, just took out the snap ring and made shims till I got the correct clearance, then reused the original snap ring.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 14 Jan 2016 at 12:28pm |
I did what Dan said.
It's important to remove the end play to obtain the spec, as those are tapered-roller bearings. IIRC, I made it zero on my D17sIV. Also, note that one side of the snap-ring usually has a sharp edge on the OD. The ring should be installed so that that side is toward the open end of the transmission. |
