6g clutch problems |
hoghead ranch
Topic: 6g clutch problemsPosted: 16 Jul 2010 at 11:26am |
i have he three bolts loose on the clutch housing but i cannot turn the adjuting ring any ideas it would be greatly appreciated.
gemdozer
Posted: 16 Jul 2010 at 12:53pm |
You need to loosen the adjusting ring locking screw just enough so that the cluch adjusting ring can be turne and tighten the cluch by turning the notched cluch adjusting ring clockwise with a screw-driver until the proper adjustement is obtained.Moving the adjusting ring 1 or 2 notches is generally sufficient and do not forget your cluch must be desangaged for adjusting and you need 30 lbs on lever for good adjustement and it not the 3 screw on housing then you need to loosen she is behind the brake cluch on the adjusting ring plate and do not toutch the 2 slotted head crews.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 17 Jul 2010 at 10:29am |
The large screw driver does the job , also a small tire iron with flat / straight tip end will work.
