620-720 |
DaveWisc.
Topic: 620-720Posted: 23 Mar 2023 at 8:14am |
What is the main differences between these?
AcFordHawk
Joined: 12 Sep 2009 Location: Boone, IA Points: 248 |
Posted: 23 Mar 2023 at 7:29pm |
Dave, the one major difference I noted is the front axle on the 720 is heavier duty then the 620 although some of the early 720s still had the lighter duty axle. Know a couple other items escape me on the differences.
IB (restoring), MF GC1705, MF 2705E
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Posted: 23 Mar 2023 at 8:29pm |
Biggest difference was decals, but the 720 came with more options available
Edited by AC720Man - 23 Mar 2023 at 8:38pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 23 Mar 2023 at 10:05pm |
a bunch of the pto stuff is differant if i rember right but mine is a 616 with a lot of 720 stuff on it
AC720Man
Posted: 24 Mar 2023 at 8:32pm |
I’m not aware of any implement differences. 2,000 rpm pto throughout the series. I have a tiller from the 616 era that works perfectly on my 720.
AcFordHawk
Posted: 25 Mar 2023 at 9:42am |
616 started out with multi piece/hanger bearing PTO shaft from engine to transmission and downdraft carburetor 16 hp Onan. 620/720 are one piece PTO shaft and have side draft carburetor 19/20 hp Onan. Same internal spline PTO connection for implements. 616 and early 620 also had narrower rear fenders.
LindaJohnson
Posted: 31 Mar 2023 at 6:23am |
Which one is better? There is a significant difference.
Edited by LindaJohnson - 18 May 2023 at 1:42pm |
AcFordHawk
Posted: 31 Mar 2023 at 10:37am |
720 with the heavy duty front axle if using a loader otherwise the 620 will do fine. 620 I had handled everything including the 52" snowblower. Used the snowblower and 60" mower on my 400' drive plus areas of our association common 1 mile driveway.
DaveWisc.
Posted: 24 Apr 2023 at 8:21pm |
Looking at 616 what are the bad parts of this tractor 16 hp vs 20 and other things???
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 24 Jun 2023 at 9:27am |
The wiring is a little different on 616 than the 620/720. Also the charging system is better on the 620/720 models.... Steve@B&B
