616-720 Fuel Tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: 616-720 Fuel Tank
    Posted: 04 Jan 2022 at 7:39pm
I have a nice restored fuel tank for the 616-720 Tractors. I glassbeaded it in and out, pressure tested it, painted it and its ready to go. $75. + the ride if interested. Will be posting some other nice clean 616-720 parts soon. E-mail-customcircuits@gmail.com
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2022 at 10:20am
Tank sold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2022 at 9:28am
Seen someone rolling one around with nuts and bolts - wouldnt that damage the piping inside ? Guess thats why you glass beaded it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2022 at 11:42am
Correct!  I have two glass bead cabinets. One for really crusty stuff which has a more abrasive media (Medium) glass bead, and the other cabinet has a less abrasive (fine) glass bead. When it comes to certain items that just need surface material removed like corrosion on electrical parts, surface rust, etc. the fine glass bead does a beautiful job removing those types of items. I also use the fine glass bead when I rebuild anything that is aluminum. ie- Carburetors, Magneto's etc. If they have heavy coats of paint on such items, I dunk em' in the tank for a day or two first. That removes the top gunk/paint. I then soap wash the item, dry it, and then it goes to the bead cabinet with the fine bead. This also in turn keeps the glass bead from getting contaminated. Glass bead isn't cheap! I bead blast a lot of chassis parts with the more abrasive media in the other cabinet. That media removes heavy rust and scale. My large cabinet is large enough for a fender off a car/truck. I can actually do a B,C,CA torque tube in it. The parts come out excellent....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2022 at 1:08pm
Sound like the way to do it ! I have one i need to do something with maybe contacting you to bead one out ,
