616-620 mower deck spindles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 616-620 mower deck spindles
    Posted: 02 Mar 2015 at 9:14pm
I need a couple of good mower deck spindles for the 616-620 mower deck. Thanks Tracy
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 12:27pm
is there a modal or seriel number ?  how wide ?   how many blades?  on the deck i will look and look and see if it crosses in the aftermarket world probley other manufacturers also used the same one also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 12:58pm
The deck is 60 inches of cut. The blades are 20.5 inches long. Three blades. It is the mid mount 60 inch deck, for the 616-620-720. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:55pm
the best i am coming up with so far is changing the oe #s to new #s and i can not find a new number for the center shaft but i think the housing #s may be murray #492574
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:59pm
HudCo what is the price of housings? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 9:41pm
there alot of spinldes out there without seeing or measureing i think murray 92574 is the right one  with bearing and no shafts about 30.00 each hope your center shaft is good its differant than the other two and prob. be harrd tofind  but go to your local mower shop that sells rotary products and look at item 2925  but look at all the differant choices and prices  this one is greaseable and a 20 inch blade is not to much to swing unless you are useing it for abrushhog  the catalog has alot of dimensions
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 10:49pm
That murray spindle looks a bit light for the application. The bearings are probably pretty small. What about the height also?
This page was generated in 0.660 seconds.
