616 hyd control lever
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 616 hyd control lever
    Posted: 15 Nov 2014 at 9:57am
is there  a two lever set up for the hyd.controls it looks like there is room one more linkage and lever set up by looking at the bushings on the shafts have not been in deep enought to see if there happens to be an extra ports on the valve
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2014 at 2:17pm
Not sure on the 616 but on the 720 there was what was called the 720 Special.  It had only one control lever to control both the front hydraulic ports and the 3 point hitch.  It is possible on the 616 that you have that they tied them together same as the 720 Special and have only one lever.  If you get to the hydraulic valve bank, you will soon know for sure.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
wsherm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsherm Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2014 at 2:58pm
Yes you can add a two lever valve.  There are mounting holes for the valve.  You would also need the hydraulic lines to go to the front of the tractor.
Bill
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 10:45pm
I have a parted out tractor. Several 2 spool valves and line sets. Easy conversion
Text or call me is best way to reach me. 336 695 2193
Dave H
Yea, I can fix that.....
This page was generated in 0.152 seconds.
