616/620/720 cooler line |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: 616/620/720 cooler linePosted: 09 May 2016 at 9:35am |
what kind of hose are you guys using? Also what ID and if you know how much I need.
Thanks David
coggonobrien
Posted: 12 May 2016 at 7:50am |
anybody?
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 12 May 2016 at 10:35am |
i used napa # atp 14864 1/2 " transmission oil cooler hose 300psi
coggonobrien
Posted: 12 May 2016 at 10:37am |
Hud you don't remember how much you needed do you?
HudCo
Posted: 12 May 2016 at 10:51pm |
no but it s only a about 2.50 a foot i think four foot piece will do it
coggonobrien
Posted: 13 May 2016 at 7:17am |
gotcha, i've noticed after mowing the first time since putting the engine back in that there was a drip on the center pulley of the mower deck so I assumed i have a line that either crack or slipped off the cooler. I went to start the mower and raise the deck and had no hydraulics. Turns out that in addition to the front leak somewhere the suction line that feeds the hydraulic filter had come off at the filter housing. Don't know how that happened as I had mowed 3.5hrs parked it fine and then suddenly it was off. Guess I should replace that one too and it doesn't like it will be much fun to play with the lower connection.
