615 diesel d2200 backhoe won’t start |
Green135
Topic: 615 diesel d2200 backhoe won’t startPosted: 08 Jun 2021 at 11:28am |
I’m new hoping someone can help I have a late 60s 615 when I try to start it when it’s just about to catch it seems like either starter disengages or engine shuts down I’ve gone through the wiring new battery rebuilt starter at a dead end
NomoreJohnDeere
Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Posted: 08 Jun 2021 at 4:33pm |
describe more or post a video.........
HD3
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4790 |
Posted: 08 Jun 2021 at 7:12pm |
Have you bleed the fuel system?
Green135
Posted: 09 Jun 2021 at 11:27am |
Yes bleed when I changed fuel filter was running fine then started doing this. I’ve looked in to it more I think it maybe be fuel shut off selnoid gone bad would than cause complete engine shut down ? Wouldn’t it just keep cranking just not start?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5142 |
Posted: 09 Jun 2021 at 12:42pm |
You most likely put a seal in the top of the filter where it doesn't belong, then it blocks fuel flow. Does this have the small cartridge fuel filter?
Green135
Posted: 09 Jun 2021 at 7:37pm |
It’s got fuel supply it was running after I put new filter on just started doing this
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
Posted: 09 Jun 2021 at 10:13pm |
i had the same issues with my 615 take a jumper wire and run it from the injection pump to your postive side of your battery and see if it firee
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 997 |
Posted: 10 Jun 2021 at 3:47pm |
If it stops cranking there is definitely an electrical issue, it shouldn't be the starter if it's just rebuilt. Did you get a new external solenoid? If you boost directly to the starter terminal the starter will not cut out if it is good.
Green135
Posted: 11 Jun 2021 at 11:02am |
Haven’t had a chance to work on i will give update as soon as I work on it thanks for all the input
